speedsensor on a E40d
30535 Views 21 Replies 9 Participants Last post by  Bashton331
The bronco I just bought has the wires torn on the elec 4wd shift motor,it also yanked out the speed synco wires ,has anyone ever relaced the speed sensor? if so can you tel lme how, I have a haynes but did not find any instructoins
1 - 20 of 22 Posts
Which year Bronco?
On my '91 the driven speedometer gear setup is part of it.
And it wasn't on the E4OD, it was on the 1356E transfer case.
It's now on a 2wd ZF. :)
Alvin in AZ
Now clarify for me the Speed Sensor you inquire about in your 1992 Bronco:
You are not talking about the Vehicle Speed Sensor (VSS) that was installed in the Transfer Case Tail Housing which sends a usable AC Frequency Signal separately to the Cruise Control and PCM which controls both engine and E4OD functions in 1990/1991 Broncos?
And you are not talking about a Vehicle Speed Sensor (VSS) that was combined with the ABS Sensor located on the rear differential which sends a usable AC Frequency Signal through the ABS Module to the PSOM, for speedometer/odometer functions, and is then sent to the Cruise Control and PCM in 1992 and later Broncos?
Are you asking about a Synchronization Unit for "Shift on the Fly"? Truly I would not know about these things because I'm still trying to figure out what the "clicky" foot switch on my floor is for... :toothless
Thanks for all the great info
This is in My 95 its on the transfer case and its wired from the elec shift motor. Miesk5, I think the stuff you posted will get me through thanks,,Bo
yw.. GL! btw, if you can, please take a pic or 3 of the sensor and post it here for others to see; not much info on this at all.
...95...
Miesk5... thanks
Bo
x2 :)
Cool stuff you posted there Miesk5. :)
Just pulled that whole works out of my '91 since I'm going ZF+2wd.
What sort of pictures are needed?
...pictures of ~'95 stuff?
...where the connections are?
A '91 module and its wiring harness laying on the ground, help any? ;)
Alvin in AZ
here is a pic I have with the speed sensor hole exposed, it's the one in the red circle, my problem is I broke the other wire (blue circle) that goes to the magnetic clutch and haven't figured out how im going to fix that yet.
Miesk5 I'll try to get some better pics of the speed sensor itself tonight if you want them as reference. The pdf you posted is the first thing I have seen that even explained what my broken wire is for lol.
here's a few pics of the transfercase speed sensor if it helps, not the best quality it was my iphone and a flash light lol
this is probably the best view i got of it
yo Drink!
Again, we have snow and Comcast is too slow for me to stay connected; so,
I can't see how you can repair the wiring without removing the rear cover, etc...
I was thinking at first of a by-pass solution is based on jumping out that wire feed for magnetic clutch, but that won't work
Basing it on 1356 Electric Shift Wiring Diagram
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at ylobronc.users.superford.org
1356 Electric Shift Parts Break Out Diagram w/nomenclature
Maybe yoomooman can jump in and give you some hints since he rebuilt his ESOF
x2 :)
Alvin in AZ
Alvin..thanks buddy! All the thnx goes to those guys & gals that took their time to post-up that info, pics and stuff!
If you have time; take pics of the speed sensor, its Connector with pin views; etc.
also if you can, have time to remove the cover and get to the magnetic clutch so db can open his up and do da repair to the wiring?
thanks! it will def help others too in da future:thumbup
...pics of the speed sensor, its Connector with pin views; etc.
...remove the cover and get to the magnetic clutch...
Yeah, I can do those, I need to fix the ATF-induced "bare wire problem"
on the 1356E so I can sell it. I'll be sure take and/or scan some pics
in the process. :)
Need a scan of the speed sensor right away tho?
Wiring diagrams kick butt for connector wire positions and for the wire
colors too. Found a few mistakes so far but nothing important really. :)
Alvin in AZ
Alvin,
Take your time on the Speed Sensor pics...
The mag clutch access is what drinkbrew needs tho
TY!
My truck will not shift into 4 LOW right now. It shifts into 4 HIGH just fine, but the light blinks when LOW is depressed. The neutral ground signal is actually 30 ohms, but even when a known good ground is applied to the red/white wires pin, it still does not shift into LOW.
The speed sensor measures 6000 ohms, way outside the 225-275 range it should be. I will replace it, and see if it fixes it.
5
My problem is I broke the other wire (blue circle) that goes to the magnetic clutch and haven't figured out how im going to fix that yet.
Just to add pics of the Magnetic clutch wire that I broke and what it takes to remove it and fix it if you have broke the same wire while changing you electric shift motor.
Thanks to Bronconut for the case housing to have this to take apart and replace my broken part. Thanks to Miesk5 for the info on the parts breakdown.
to remove the magnetic clutch you can see the three nuts in the next picture
I know this thread is old but what does the magnetic clutch do?
Transfer case magnetic clutch
When the 4x4 button is depressed, the electronic control module energizes the electronic clutch coil in the transfer case (i.e.: magnetic clutch). This accelerates the front axle shafts up to the same speed as the front wheels. As the axle shafts begin to rotate, they engage the automatic hublocks located at each wheel end. After approximately 5 seconds, the transfer case clutch coil turns off. A stepper motor located on the back of the transfer case then locks up the transfer case via a camming mechanism and a locking collar. The entire sequence takes only a few seconds.
4
yo,
For posterity;
Workshop Manual
DESCRIPTION AND OPERATION
Electronic Shift Operation
The transfer case (7A195) is equipped with a magnetic clutch, similar to an air conditioning compressor clutch, which is located inside the transfer case adjacent to the lockup collar. The clutch is used to spin up the front drive system from zero to vehicle speed in milliseconds. This spin-up allows the shift between 2-high and 4-high to be made at vehicle speeds listed in the vehicle owner's guide. The spin up engages the front locking hubs. When the transfer case rear and front output shafts reach synchronous speed, the spring-loaded lockup collar mechanically engages the mainshaft hub to the chain drive sprocket and the magnetic clutch is then deactivated. Shifts between 4-high and 4-low can only occur with the transmission safety switches closed. The vehicle's speed must also be within specified limits as determined by the transfer case speed sensor (3 mph or under).
Electronic Shift Control System
This system consists of a two-switch control system, an electronic control module, an electric shift motor with an integral shift position sensor, and a speed sensor.
Switch Control System
There are two control switches located on the upper right corner of the instrument panel for fingertip shift control. The two switches are mounted horizontally and are identified as "4x4" and "LOW RANGE." Two indicator bar lamps are located in the instrument cluster.
When either of the two switches on the instrument panel control are depressed, the first thing that happens is that the electronic control module receives input from the transfer case shift position sensor to verify what position the transfer case is in (2H, 4H or 4L). Next, the electronic control module looks at the speed sensor and the park/neutral position switch or clutch pedal position switch (depending on transmission type). If all conditions are correct to allow the desired shift, the electronic control module will tell the electric shift motor to execute the shift. After the shift has been made and the electric shift motor is off, the control module again looks at the shift position sensor to make sure the proper shift has been accomplished. Finally, the dash indicator light and the push-button light on the control panel will be illuminated by a signal from the electronic control module indicating the desired function has been completed.
In Diagram c11461b below;
7017 Input Shaft
2 7A398 Front Planet
3 7100 High-Low Collar
4 7177 Sprocket, Drive
5 7G361 Electromagnetic Clutch
6 7106 Lockup Sleeve
7 7D126 Lockup Spring
8 7061 Output and Fifth Gear Drive Shaft, Rear
9 7289 Shift Fork, 4WD
10 7219 Lockup Release Spring
11 7G360 Transfer Case Shift Motor
12 7A029 Drive Chain
13 7061 Output and Fifth Gear Drive Shaft, Front
14 3B396 Hub, Auto Locking
15 7N095 Shift Shaft
16 7W074 Range Shift Spring
17 7289 Shift Fork, Range
Electronic Control Module
The electronic control module, located on the passenger side, controls the operation of the transfer case in response to inputs to the push-button control by the vehicle operator, the speed sensor, shift position sensor and the park/neutral position switch.
Speed Sensor
The speed sensor, mounted on the rear of the transfer case, tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur.
Shift Position Sensor
The shift position sensor, an integral part of the electric shift motor, tells the electronic control module the shift position of the transfer case.
Electric Shift Motor
The electric shift motor, mounted externally at the rear of the transfer case, drives a rotary helical cam which moves the 2W-4W shift fork and 4H-4L reduction shift fork to the selected vehicle drive position.
Borg-Warner 13-56 Electronic Shift Transfer Case
Item Part Number Description
1 7A039 Extension Housing
2 7B214 To Rear Axle
3 7A195 Transfer Case
4 7E063 Skid Plate
5 7B214 To Front Axle
6 7G360 Transfer Case Shift Motor
7 � Wiring Connector Mounting Bracket (Part of 7G360)
8 � Shift Position Sensor
(Part of 7G360)
9 87675 Fill Plug
10 7B214 Case Yoke
11 7F239 Speed Sensor
12 � Wiring Harness Connector
(Part of 7G360)
13 87675 Drain Plug
NOTE: Remember that electronic shift transfer cases do not have a selectable neutral position. Because of this, if vehicles equipped with electronic shift are to be towed for long distances, the rear driveshaft should be disconnected. If this is not done, the transfer case (which is protected by positive lubrication) will drive the transmission, which is not lubricated when the vehicle is towed, and may cause damage to the transmission.
I know this is an old thread but I'm hoping someone can help.
I have a 1995 Ford Bronco 5.8 with the push button 4x4. It failed me once on the beach and it corrected itself sometime in between me running the self test and tapping the motor. It worked all winter long after that. Then I totalled it and rebuilt the front clip. Also swapped in a new dash. I know that leaves a lot of room for error in plugging things in but I'm pretty sure everything is where it was.
Now its 4x4 beach time again and it wont go into 4wd.
I ran the self test, it blinks 4 times. I also testing the position sensor using the 4x4 diagnosis thread info from here- and the positions all test where they are supposed to be when its in 2wd.
I havent pulled the transfer case motor yet-because I am not hearing any "clicking sound" from the relays or from the motor itself when I hit the 4x4 button on the dash. The button is plugged in. I also tested the button for continuity to the module in the right kick panel and both switches show continuity when pressed to their respective wires. All my fuses have power and the 2 relays in the engine bay look fine.
What could prevent the motor from atleast trying to shift into 4x4?? Which wires should show 12v power being sent to the motor when the button is pressed? Is there anything that jumps out at anyone here that I should test? I know I can pull the transfer case motor and pull its pins out or cut and splice the wires but my gut tells me that it should at least click when I press the button...flame away friends...
1 - 20 of 22 Posts
