1 - 4 of 4 Posts
It is for my 96 Bronco TTB I destroyed my passenger side outer axle (halfshaft) and universal joint and was gonna replace them from a spicer dealer in town,
but for some reason he is not sure what the exact part numbers are :banghead ...He wants me to take the parts in to match
I am taking them off tonite but the part numbers would be helpful..
I tried searching but this is a needle in a haystack searching "spicer" or any combination :whiteflag
this will get you the u joints... http://www2.dana.com/expertforms/dek350.aspx
yours are 5-1203X 5-790X 4,5,6
5-1204X 5-792X 2,3
it even has a diagram to show you where each one goes
as far as axle shafts etc,check out these catalogs
http://www2.dana.com/pdf/X510-2CVSP.PDF
infact...anyone with a ford 4x4 using a dana should download that pdf...all the part info you're gonna need.
also, if you ever need to look up ANYTHING from dana/spicer go to http://www2.dana.com/expert/wc.dll?cvsp~depdf~2~
thatll get you to the "library" with all the catalogs
Oh, and you're going to want page 18 of that pdf. thats specific to the fsb broncos dana 44. (page 18 that is printed on the bottom of the actual document..for some reason its page 25 if you go by the page number that acrobat gives you)
page 28 will give you just a chart of the part numbers you need for a 96
RIGHT HAND SHAFT ASSY.74820-1X
LEFT HAND SHAFT ASSY 74813-1X
SHAFT & SLIP YOKE ASSY.72041-1X
please download and look up yours on a PDF if you dont have a 96, as the part numbers vary with the generations...
1 - 4 of 4 Posts
