Steves method works good to. You really have to pound the shite out of the races with the slide to get them to pop. I mean, really really hard. Glad you read that, hope it helped at least a little!!!:rofl:
I read through that thread about 5 times before starting this project. I even used it to determine what tools I needed to borrow from AutoZone. I must be a complete retard because the method you described to remove the spindle bearing did not work for me.
I can't even find those parts on the NAPA site :whiteflagI just went through this with NAPA parts. The first thing he brought out was some bullsheit pieces - a metal slinger washer and a cheesy rubber-only gasket. I have a '96, but I cannot see them being too different. What I needed was:
B2110 Spindle bearing $12.50 ea
13144 Spindle seal $3.96 ea
18844 Axle seal $7.91 ea
(goes on the axle and rides against the spindle seal area)
--MIKE--
...you don't need to worry about what way anything faces.
Of course, using the parts that I gave from NAPA, if someone *WAS* able to install them wrong, then they don't belong doing the work, or doing any water crossing.Man, I wouldn't want to see the insides of YOUR hubs after some fording... :duh
Careful how much you chose to quote. ANYTHING can be taken out of context as you've just proven. ;-)use the same parts I did and you don't need to worry about what way anything faces.
Stan, cannot comment on their website. I tried it myself, and it is not working for me either.I can't even find those parts on the NAPA site :whiteflag
Yep, you really gotta be careful about taking things out of context...Of course, using the parts that I gave from NAPA...
Because that might make it REALLY difficult for someone to know wtf you're talking about. :shrugI use a NAPA 18844 on the axle shaft ('96 Bronco).
http://www.napaonline.com/NOLPPSE/(S(u5sgux45qpnmoz45scs3z0zn))/Detail.aspx?R=NOS18844_0068955039
and a 13144 to seal the backside of the spindle.
http://www.napaonline.com/NOLPPSE/(S(u5sgux45qpnmoz45scs3z0zn))/Detail.aspx?R=NOS13144_0070438845
No worries Mike, JBG sells a kit for $12 for the 93-96. It has a new spindle bearing and both correct seals :thumbupStan, cannot comment on their website. I tried it myself, and it is not working for me either.
I have the receipt, and that is where I pulled the numbers from. I've been down the road a few times with different NAPA's until they got me the parts I wanted. I always wound up with the wrong ones the first time around (the ones with the separate plastic and rubber parts that you have to figure out what to do with), so now I walk in with the part numbers and ask for those specific pieces. Problem solved.
Since the link was following the part numbers, I "dare" say a web page that expires is less of a "problem" or "offense" than you misquoting me to make me look like I did something wrong, or was somehow less of a "man" than you are. Though you generally supply tons of good info, it is not a license to attack someone and bring down the value of a thread, Steve. Learn to work with "normal" people instead of always being "like that." :bangheadYep, you really gotta be careful about taking things out of context...Like links to dynamic web pages, or sites that use sessions, which can expire.Because that might make it REALLY difficult for someone to know wtf you're talking about. :shrug
Thank you.Start on this page, click "PartsPRO SE Catalog", switch the radio button to "Part Number", and enter "nos18844" or "nos13144" in the search box. :deal
