Alright, well the key & the switch both dont work, though the interior light dims & the needle on the dash goes nuts when you hit the switch inside. I can however push down on the rear window a little and then the key will lower it a little then it stops and grinds. I can push on it a bit more then it will lower it almost all of the way down with the key. Then when i try to raise it, the key does nothing unless i pull up on the window and raise it just a little by hand. Then the key will continue raising it, but then it hits that spot again and starts to grind until i raise it by hand once again just a little. Its like its getting stuck until you help it out a little. Whats the deal here?
