167 could be operator error. Did you goose the engine when doing the KOER? If not, it would not have opportunity to read the TPS.
yo,
The code may have been set if you disconnected the battery.
Clear the code the normal way with STI wire but do not disconnect the battery.
Check codes to make sure it is gone.
Drive it then recheck codes.
thanks for jumping on my thread miesk5. Hoping not to sound like a d/a, what is the "normal way" to reset the code? I ground the STI wire when i do the KOER check; is that what "clears" the code? I will perform the voltage checks as prescribed tonight and follow-up with results. thanks.
Can you clear codes by turning off your code reader before the KOEO test completes, or do you have to use the jumper wire method? My code reader suggests removing the battery cable...mkt2488, I'm with you brother. I LOVE it when miesk5 takes interest in one of my threads, and adds his knowledge and expertise!
I believe that he is referring to the "normal way" to clear codes is this:
To clear codes from memory, simply terminate the KOEO test before all codes are finished being displayed by removing the jumper wire at the self-test electrical connector.
The alternative way to clear codes is to remove the battery cable. That will also clear the fuel trim tables. Miesk5 recommends that you do not pull the cable, and while I do not know exactly why... *I* would follow his directions.![]()
Probably... try it! Then pull codes and see if they are gone. If not then use a jumper wire and pull codes the old fashoined way. Then clear them the old fashioned way.Can you clear codes by turning off your code reader before the KOEO test completes, or do you have to use the jumper wire method? My code reader suggests removing the battery cable...
