1 - 4 of 4 Posts
I cant seem to locate the spout location.. its a 1986 302 all the wires were taped up going to the dizzy so i cut the tape off, and found the yellow wire where i think the spout connector is supposed to go.. it has a butt connector connecting the yellow wire together.. am i on the right track? Is the spout connector a yellow wire?
thanks
the yellow wire was the spout wire.. i put a new ignition module on so i had to turn it so i could take it off, i put it back where i thought it was originally,i used a timing light.. it was at 5 degrees atdc.. i set it at 10 degree..so it was a 15 degrees off.. i cant believe it was running that retarded..
2006 Lincoln Navigator
Glad to hear you got it fixed
1 - 4 of 4 Posts
