Does anyone know a site/page that lists the spring rates for each suspension manuf.'s coil springs?
Why's that? :shrugbest fullsize springs out there are the fabtech 2wd coils
i didnt get any e-mail from uchris, i sent you a email to your yahoo addy
aren't those coils progressive rate too?plug ugly said:best fullsize springs out there are the fabtech 2wd coils, just get ones 2" bigger than the lift you are going for. i.e 6" lift requires the 8" coil
you're a good guesser.i'm not running them though.We put them on evilbronc's truck for the SAS :thumbupDRK said:NOBS are you running 8" ranger coils? I guess the spring rate would be considerable less and should provide more flex.
DK
Your ttb won't flex much better with coil swap.Your brake lines and shocks will limit as is.Undo your shocks and see how much more droop you get.DRK said:NOBS, how did it work out on Evilbronc's truck? What is the ride like on the trails? How's the flex? I've got the TTB now with a 6" skyjacker class II, but really want more flex from the front end, and may go SAS with some soft coils. Sounds like evilbronc has done what I am considering doing.
Do you know what the spring rate on those 8" ranger coils is?
DK
