1 - 9 of 9 Posts
Engineer
does it fit in the shaft? if it does its probably alright
I'm far away from any good store here and just want to make sure I have what Ineed before I rip the front axle apart. If a typical chebby spring of 1.25 OD will fit, my 30mm spring is a lot softer and good enough.
Just took it apart, 30mm OD spring is just fine, I think 33mm is an absolute maximum.
Edit:
My spring length is 1.25" and you might have to be a bit angry to get a 33mm OD spring in.
Satyr of the Midwest
C-clip elimination for the passenger side axle. So it's nice & easy to just pull the sucker out of the pig instead of having to drop the entire differential.
1 - 9 of 9 Posts
