I just got my 86 Bronco back on the road. It is a 302 with a 4 speed manual. Anyway, when I am idling in neutral, the clutch makes a squeeky sound unless I slightly depress the clutch. This also happens when I am driving it. It always goes away if I just barely depress the clutch. It is giving me a headache. Any ideas on what is causing the noise?
Sneaky Ba$tard
Bad clutch, bad throwout bearing, bad pilot bushing or bad likage adjustment(don't know if your hydro clutch or not).....My guess would be you need a new clutch though........I'm doing mine this weekend...Fog
aka: kemicalburns
when you put the throw out bearing on did you grease the input shaft and the inside surface of the bearing.
