1 - 20 of 28 Posts
Do they make a zf6 tranny for a 460, or just the deisel's?
Because I know that they make a zf5 trnny for the 460, and i'd like to get a 6 speed so i might actually be able to have my truck as a daily driver
no the 6 speed is only for the mod motor or powerstroke. the only difference is the low gear the 6 speed has . they both have the same overdrive ratio
by mod do you mean 351 M or another motor?
i do believe he ment a 351M. dumb question 1979 Bronco, 400 M, Ranger, 5" lift, 36" Super Swamper TSL/SX-Blown Motor?
had to ask, i've heard of the 351 m being called many different things for the M
I'm fairly new to the board, so I hope that statement was meant as a joke. "Mod" engine is reference to the Ford modular engines, the OHC 8 and V-10 engines.
http://en.wikipedia.org/wiki/Ford_Modular_engine
The ZF6 wasn't introduced until long after the "M" blocks were phased out.
i like how you quoted me,
i said.i do believe he ment a 351M. dumb question 1979 Bronco, 400 M, Ranger, 5" lift, 36" Super Swamper TSL/SX-Blown Motor.
a mod motor in 78-79 is a modified. not your modular motor. you want to quote me? please quote me, and not parts. heres a pic of my 351M. MODIFIED:goodfinge
that zf6 trans sucks. it bolted to my 351`m. it never with stood my 351m. good luck.
Convicted Drunk Dialer
Thats not a picture of a 351M. Also, "i do believe he ment a 351M. dumb question 1979 Bronco, 400 M, Ranger, 5" lift, 36" Super Swamper TSL/SX-Blown Motor?" doesnt make a bit of sense. AND, there is no "400 M." AND, he did mean modular. Basically, a dumbass cant be a very effective asshole, so stop trying.
We've been building 351m/400 engines for almost 30 years..and I knew that 'mod' or 'mod motor' is the common short/slang term for the OHC series of Ford modular engines..:popc1:
gulfcrestinc should be the only one to respond to what he meant because obviously no one has any real clue on what he meant
Considering that the ZF 6 was only offered for the modular motors and Powerstrokes, he obviously meant modular. This isnt that hard, people.
I'm confident that beast of a 351M you built completely destroyed a transmission with a 600lb/ft torque rating.
Maybe it committed suicide when it realized its owner had no idea what he was doing.
Oh, and to finally answer the question, NO - a ZF6 won't bolt up to a 460. ZF6 has an integral bellhousing, with the modular bolt pattern. Unless, of course, we're talking about the rare prototype one-off ZF6 with the 351M/400/460 bolt pattern (you know, the one that 1978custom sourced from alien invaders for his bitchin' 351M build).
I thought that there was a ZF6 put behind the diesels. If there is it would bolt to a 460.
yup, I got one in my 2001 f250.
the 5 speed zf has a low 1st gear as well.
press ALT+F4
There's a lot of conflicting info in this thread. Can we clear up a few things here???
yeah i meant modular motor 4.2 4.7 5.4 6.8 all the same bellhousing pattern
You bolted a ZF6 to a 351M? Then that transmission would bolt up to a 460 as they have the same bellhousing pattern.
4.2 is a v6 is not a modular motor. It has the smallblock bellhousing bolt pattern same as a 5.0, 5.8. You must mean the 4.6 v8?
460 and diesels have different bellhousing patterns.
I have read that the ZF5 Diesel trannys can be modified slightly to work on a 460. I am not sure if it is true or what is involved but the same thing would go for the ZF6. I am hoping it is possible because I'd love to put a ZF6 behind my 460 (currently a ZF5).
diesel trans have different ratios compared to the gas versions.
1978custom just goes to threads and makes up retarded posts so he can upload pictures of his truck that no one cares about....
1 - 20 of 28 Posts
