1 - 20 of 72 Posts
It started out Jan 09 when I bought it. It went from stock and 35's to 6" and 35's to 6" and 38's and now to 10.5" and 38's in the works with a 78 D-44 HP. They will be loaded with 4.88's and a Aussie locker and a lincoln locker 8.8 out back.
So here is some start to now pics. Will post more as it comes along.
Stock
First rear bumper
cash for clunkers front and rear bumpers
6" and 35's
Homemade Cross Member
AAL install
6" and 38's
The new tail gate
now the shackle flip
stock spring, shackle flip,1" AAL, and a 3" Block = 8.5"
D-44 parts
I have the gears, springs, locker, seals, bushings, and the DOM and Heims to extend the Radius Arms. This will come when I have the time at home to start and finish it.
Mud God - R.I.P.
Cool build.
on the rear take some 3x6x1/4 and build a block-perch
you can drill the hole where you need it
Discussion Starter · #18 ·
well I have to buy a F-350 drag link tomorrow, build the track bar and mounts and have brake lines made. Here it is on her own weight and the boggers. and for some reason i had to drill the spring cups out because the hole did not match up but its together now. this puts the bottom of the fenders at 32" from the ground.
Discussion Starter · #20 ·
Well the shocks came in today and I built the track bar mount last night. So I should be working on that Saturday or tonight.
Now I need to burn all the welds in, replace the rear wheel Cyl's, and put the rear locker and ring and pinion in. and its wheeling time.
So far here is a parts list I have used
78 D-44 HP from a 78 F-150 / craigslist $100.
1.5 DOM and Heims to extend the RA's
Custom X member out of DOM
7* C Bushing kit from JBG
Motive 4.88's front and rear / National Drive train
D-44 Aussie locker / FSB member
8.8 Detroit Locker / craigslist
Welded the D-44 axle tubes
Alll new bearing and seals. Much cheaper from JBG
78 T-Bird calipers. Auto Zone
Custom made brake lines from a local hose shop. $40. HOW Rubber in OKC
9" Superlift coils. / 4 wheel parts
2 shocks from JBG PT# 23430 for the front.
6" lift shocks with relocated tabs for the rear.
stock 88 FSB coil buckets (not relocated)
stock 78 Track bar with new bushings.
93 F-350 Drag link and tie rod ends. Orielleys
Stock 88 FSB pitman arm. laying around
1 - 20 of 72 Posts
