1 - 3 of 3 Posts
Got everything removed and put the cam in then ran into my first issue. When putting on the cam plate that holds it on one of the bolts broke. Went by autozone orielly advanced and even home depot. Noone seems to have a bolt. Anyone know where I may be able to get a new one or am I gonna have to hit the junkyard. Gonna try and find oe tomorrow and hopefully get as much put back together as possible before work. Also when lifting the motor to replace the oil pan gasket do I have to remove the transmission mount bolts. I have plenty of room to lift the engine with the heads off. Thanks
You are better off to loosen/remove the trans mount bolts,
makes it easier to get the job done,
won't have to worry about putting stress on the mount.
I had to go to the dealership to get the new nuts for my torque converter... the price wasnt bad, but the drive was...
1 - 3 of 3 Posts
