ok so i searched the forum and i did all the things that i found about this problem..... When i turn my key to the run position my starter kicks on and proceeds to crank until i eather turn the key back to the off position or i pull the little wire off the solanoid... so far i have replaced the ignition switch, replaced the solanoid, replaced the lock cylinder, and had the starter tested (passed), and i have checked all my battery grounds... and guess what the problem is exactly the same.
