i have a 1988 Ford Bronco 2, manual (5 speed), 4x4
so my starter went out,and i replaced it. But with this new starter i keep hearing this really bad grinding noise,and i have no idea what is wrong. There was no problem/ grinding noise with the old starter. so any idea's ?
Are you sure your starter went out....Or did your battery go dead? In any case it sounds like your not getting enough power to the starter-make sure your terminals are clean and that they are on tight.
FSB Pimpster & Recruiter
you might want to check you have the correct starter and make sure its in there all the way if it is.
I agree, you might of just got a starter for an automatic when you have a manual or visor verse ??? :shrug
Allcruisen :imp :usa
