when i started my truck this morning (clutch in, shifter in first) i got a quite awefull grinding noise... i immediately took it out of gear and let off the clutch, it stopped grinding, but when i depress the clutch and try to put it in gear it grinds again.
i shut the truck off and when i turned it back on everything had returned to normal.
the second time it occured i just shut the truck off like before to try again but when i turned it back on the Brake warning light and the ABS light came on and stayed on, i drove and my brakes felt fine. the lights went away the next time i turned the truck on.
the third and final time this grinding noise occured, instead of turning the car off it seems i just turned the key back a click and the noise went away.. as if my key was stuck in the "start" position, but i dont remember having this option the first two times.
it is a rather high pitched grinding noise, almost like a starter gear... i thought i may be having the same symptoms as Baldkrys was having with his starter that wouldnt stop. the deal with my ignition switch also made me think this, yet since mine also had to do with the clutch and trying to go into gear i decided to create a new post
thanks all!
thanks all!
