1 - 4 of 4 Posts
Hello everyone,
I have been searching the threads for a long time, but I can't find anyone with the same problem. Every now and then, when I turn the key to start the bronco, the starter does not turn the engine over at all. I know something is going on though. I hear a clunk sound and then a sort of mechanical wizzing sound. It almost sounds as if the starter is spining, but it hasn't engaged the fly wheel. After a couple of tries, it does turn over and it won't do it again for a week or two. I apologize if this seems obvious, I just want to double check if my theory seems like the possible reason for this strange occurance. Thanks for your help!
Lick my balls
Sounds like your starter solenoid isn't working right. Check and see that you have a solid connection to the starter and the relay on the fender by your battery. If those are good get down there, by your starter and have someone try to start it up, observe what happens. Repeat several times if necessary.
Actually the solenoid is working.You starter is spinning,the wizzing sound,the starter itself has a bad bendix,sticky bendix which isn't kickin the drive gear out,IMO just get yourself a rebuilt starter and you should be good to go.
Thanks for all the help. Thats why I like this site. I am going to pull the starter out then. thanks!
1 - 4 of 4 Posts
