I need a new starter relay to starter cable. Mine decided to break off at the starter. It's the little red wire. Will post pictures if needed. Where can I get one?
Just buy some bulk 12 gauge wire and crimp/solder some ring terminals on each end. You can get the wire and terminals at any auto parts store.
The wire I am talking about is the starter solenoid trigger wire in this diagram. Now, do you need that black cover that holds the battery to relay and relay to stater cables?
No, you don't need that black rubber thing. Speaker wire comes in all different sizes, 12 gauge is one of them. The gauge just tells you how thick the wire is, and thus how much current it can carry. The factory wire is 12 gauge if I remember correctly, and should be plenty big enough.
