US, 89, 5.8,C6, 1356 BW (manual), 5 Bolt Hub (automatic) No modes like to keep it or
I need some input to see if I did this correctly and if my assessment is correct.
So I recently had to take apart and put back together my cylinder lock. I made sure the key was in the RUN position when I put it back in and that the actuator was fully forward (towards the fire wall). When I went to start the engine, I got ACC and in the RUN position (fuel pump engaged, had instrument lights etc..) When I went to start position nothing not even a click.
I have also been digging into a bad blower switch, that had me researching how to do a voltage drop test. So I thought what a "great time" to apply what I think I know.
So I opened my electrical schematic and started at source the ignition switch. I double check bat voltage it was 12.40V. Went to the ignition switch checked voltage across the Yellow wire (brings in the power) and R/LB (what takes the power to the starter relay) Voltage was 12.37V and when put the key into Start it dropped to 12.00V right at the limit of what I was told of allowing only a 0.4 drop in volts.
I then I placed one probe on the POS Bat terminal then the other probe on each connector (front and backside) back probing all along the R/LB wire through each connector. I went from the Ignition switch to connector 100 (52 pin terminal to C114 that leads down to the neutral safety switch. I could not get to the actual component of the NS ( I just did the R/LB coming to the pigtail C276 and back up to C114) I then followed C114 to the S-terminal to the Ignition Relay. All along the way I read 12.4-12.39 Volts with a drop of 0.35 - 0.27 to the S-Terminal.
Once at the relay and the key in Start I wanted to test the relay between the S-terminal and cable leading to the starter to see if it was still good. So I removed the R/LB wire from the S-terminal and took a screw driver and jumped the S-terminal and positive battery cable hooked to the solenoid and the Bronco cranked right up.
So if voltage is getting from the ignition to the S-Terminal with a drop of no more than .35volts (reading from positive batt post to the connection) and the relay from the S-Terminal to Start Cable works what am I missing?
Should I take apart the lock cylinder again pull the actuator all the way to the back (towards the driver seat) to allow just a little more turn of the lock cylinder in case the ignition switch was not hitting start, but that would not make sense because I get power to the S-terminal ?
Again what am I missing?
