If it has a warranty, exchange it for another.
I've never had to use a starter shim on any of my ford vehicles.
I said no based on an answer by someone that knows a lot about fords in post 9, that and I've never seen a shim on any ford starterthey do make starter shims for fords.....usually by the 'help' section.
i would do like justin said.....exchange it for another.sounds like the bendix is screwed up on it.
i had to use a shim on a powermaster mini starter, would not engage the flexplate....after a shim, worked like a champ after that.
If the flywheel has gotten closer to the motor, why would you want the starter further from the motor? That dosn't make sense to me.I've had to use shims, or maybe call it a shim plate? It's in the HELP section of the parts store. I have no doubt that it has as much or more to do with other problems with the vehicles, but if a $3 part lets you get on the road then personally I'm going to use it.
as to ford never needing shims.........
TECHNICAL BULLETIN:
Ford Starter Shims
ALERT: FORD STARTER DRIVE FAILURES
APPLICATION: All Ford Inline 6 & V-8 Engines, 1963 thru 1991
PROBLEM: Ford starters come in (either a core or alleged defective)
with the clutch retaining cap on the drive cut off on the front side, or worn from running against the flywheel.
REASON: The engine flywheel is floating. The crankshaft thrust bearing that keeps the crankshaft centered wears after about 60,000 miles, allowing the whole crankshaft and flywheel assembly to move toward the front of the engine.THIS IS NOT THE FAULT OF THE STARTER:
**REFER TO FIGURE 1 AND FIGURE 2 BELOW**
SOLUTION: Ford Motor Company has made a shim to correct this problem. The part number was D6TZ-11N004. It was .090 thick and fit between the starter nose housing and the bell housing. thus backing the starter away from the ring gear. Ford has discontinued this shim.
**THE SHIMS ARE NOW AVAILABLE THRU H. M. C.**
HOPPER MANUFACTURING COMPANY INC.
8500 Carbide Cr., STE 3
Sacramento, Ca. 95828
(916) 688-8960
If possible always inspect the customers core to detect this problem in advance. You will save both, yourself and the customer a lot of time and money.
wtf would that have to do with it?i had to shim a starter on an automatic,brand new starter, brand new 351w short block.i don't know why it works, but it does.:goodfingePeople that ride the clutch a lot get this problem .
Riding the clutch pushes forward on the crank and eats up the thrust bearing . Having not enough free play will do it too.wtf would that have to do with it?i had to shim a starter on an automatic,brand new starter, brand new 351w short block.i don't know why it works, but it does.:goodfinge
TECHNICAL BULLETIN:...
How does shimming the starter fix a bad thrust bearing :shrug :twak
Blame yourself - you went there... :shrugThanks AutoZone for the headache.
