Well i think i gather all my necessary fittings, brackets, hoses and everything in between to start my oba.
Today i got my switch and bracket from offroadcontrols , looks nice
and the rest of the stuff
i think the tank is a bit to big, don't know if i'll keep it or just get a smaller one
and i don't really like the brackets
i'll keep you guys posted.
Do you think that my switch is set too high?, its a viair set at 110psi on and 145 psi off, and my safety valve is a 160 psi.... I didn't think it was to high but after doing some more research i think it will have too much pressure.
Administrator
what are you using for a compressor?...I noticed that when I was running a quick air 2 electric compressor that a higher cut of switch caused the compressor to really lag at the last few pounds...I went from a 145 cut off down to a 110 cut off switch.
oh yeah, i'm running a york that i got from frogmann, damm fittings are expensive, i got the york with the roto lock, and i dind't go with the onboard air fittings because they cost 2 much $$, i got fittings from my local hardware store instead, it cost me about 30 some bucks, which is not that much cheaper but at least i save couple of bucks... Those damm fittings are so hard to get....... i'll post a pic on a lil bit.
here are some pictures of my york (kind of dark, didn't want to bring it up to the house)
and with the filter
and this is for the output side
5/8 female to 5/8 female ; 5/8 male jic to 1/2 npt female; 1/2 npt to hose ...
and the gauge with pressure switch and relief valve
and the bracket is from bronco air.. it is somewhere in the garage.. :shrug
Enjoy my
Where'd u get the tank from?
I see Broncos
Tim it's a York 10 out of a 78 Mercades.
