1 - 20 of 87 Posts
Today I get rid of my TTb and mounted the SA coil buckets....I moved them forward about an inch.....and now I´m going to dismount everything to be painted......the next step is to wait for all the parts to rebuild the SA that I think I´ll have them in 10 days.....here are some pics
Shot at 2010-05-08
Shot at 2010-05-08
I knew I could do this some day:rockon:rockon
Shot at 2010-05-08
Shot at 2010-05-08
Shot at 2010-05-08
Shot at 2010-05-08
Shot at 2010-05-08
Shot at 2010-05-08
Good start. Sorry if I'm wrong on this, but aren't you the one that bought a 78 but couldn't title it? If so, are you parting it out to do the SAS?
yes, you are right.....that´s me......I knew that I couldn´t title it....but I paid for the whole truck the same price than a SA D44 cost in my country.....so the rest is almost free....and I allways had the SAS idea in mind since I bought it...
new updates....
Shot at 2010-05-16
Shot at 2010-05-16
[Why is all that dirt in there??? Is any way to put an outer seal in here??:shrug: :shrug:
Shot at 2010-05-16
Shot at 2010-05-16
Shot at 2010-05-16
Shot at 2010-05-16
Discussion Starter · #9 ·
nice henri.......cait wait to see it all back together.....
Discussion Starter · #11 ·
What did you clean that axle with? looks great!
I cleaned it with a degreaser. phosphating product....eliminates all the oxide and corrosion....You have to let it work for a couple of hours and then clean with a lot of water.I used the same product when I did the interior of my truck.
looks like you're making some good progress. Ill have to get some of those outer seals for my rig as well
Discussion Starter · #15 ·
I did some mods on my steering linkage........and did the TRES with bigger tie rod ends.
By montecarlo at 2010-09-01
By montecarlo at 2010-08-26
The D44 cover.....:toothless:toothless
By montecarlo at 2010-08-05
Discussion Starter · #19 ·
Those are some burly TRE's !! Where did you order them from?
In my country it doesn´t exist the common chevy TREs that you use there or nothing like that....so we made this special part from 1 piece 1045 steel that will work like an adjusting sleeve and has the fiting for the drag link also with bigger tie rod.
The tie rods ar from an F7000 (truck)
By montecarlo at 2010-09-02
Discussion Starter · #20 ·
Here are some pics from today
I left the axle hanging with 2 threaded rods so I could set the same height in both sides....by adjusting a nut on top of the spring bucket.
1 - 20 of 87 Posts
