Drill two small holes at the ends of the crack to prevent further spreading and then weld it good/brace it with welded extra plates
Sounds good.The plate should be on the outside. Using angle iron is not a good idea. You want the face plate and wrap under to be all one piece. You only going to move the box 3/16". You will only have to lengthen the drag link. There should be plenty of adjustment in the link ends.
Yo,@miesk5 the link to this picture does not seem to be working for me. See below.
Jopes had a 78 and wrote, "hard to see mine. but it goes from the coil tower past the front of the ps box. 3/8" plate. welded all the way around. my frame ripped as well." http://www.1ton4x4.com/steering/DCP_6921.JPG
Some owners have reported same cracks in their Broncos from 1978 through 1996.
Also, does that TSB you posted also apply to 78-79 trucks? It looks like it is specifically for 83-96 model years.
Yeah, it's a thing. My 78 had some small, hairline cracks in the frame right around the steering gear bolts. I don't have the equipment or the skill to fix something like that, so I had a shop weld them up and plate the frame. I don't have pics of it, because of that, but at some point I'll pull the box off the frame and take pics for myself as reference.I never knew this was a thing. Chevies, yes common but never heard of it on half ton fords
I just ordered some custom frame plates to reinforce the steering box and the shock tower that the track bar bolts to. It is 1/4 plate steel and has all of the holes laser cut into the plate.All the corners are radiused so there are no 90 degree edges and it has clearance holes for the two rivets going through the frame with enough room that you could drill them out and replace them if needed in the future. There was not much difference in price for them to cut one plate or multiple plates so I ordered extras and I am hoping to sell a few to offset the cost of mine. I will post pictures of the plates when I pick them up next week if you are interested.Does anyone have any pictures and/or write ups on what they did to repair cracks in the frame where the steering box bolts in on a 78-79? I've seen several discussions about it, but not a ton of pictures. The drivetrain is coming out of my truck soon so I thought that would be a good time to go ahead and address the cracking.
Yes it is for a 78/79 Bronco. Here is basically what it will look like. The two holes towards the back are for the shock tower/track bar mount, the three smaller holes are for the steering box, and the two large holes are for clearance for the frame rivets. I rounded the front of the plate so there would not be a vertical weld, but there was nothing I could do on the back because the coil bucket sits right next to it. I rounded all of the corners to avoid square points, hopefully that will help.Yeah that sounds great! I'd like to see some pictures. I may be interested in one of them for sure. You are talking about one that will fit a 78-79, correct?
