1 - 11 of 11 Posts
got mine from jeffs. all it had was seals, couple snap rings and a new lock nut for the top of the sector shaft.
and it did not have the real small oring that goes on the end of the input shaft that sits inside the spool valve.
I do beleive the kit worked just fine on the bearing and non bearing sector shaft.
I've done a couple with Napa kits. The Gold line is good quality. The rebuild is pretty simple. The only part you really need to keep an eye on is that there are two sizes of recirc balls that must be kept in order (every other one). As long as you don't mix up the balls or stretch the teflon seal rings too far, you should be good.
BTW, once you have the box apart, it only takes a half hour or so to drill and tap it for hydro assist. Do the mods and put in pipe plugs, then you'll be ready to upgrade without pulling the box again :thumbup
1 - 11 of 11 Posts
