1 - 3 of 3 Posts
I hate the steering wheels from the 92, I really prefer the look of the 93 and later steering wheels and I'd love to swap em out. I have sourced one but, before I start pulling mine apart, has anyone ever attempted this?
Is it even possible?
Thanks!
pretty much all ford steering wheels are the same. If you pull the entire column from a donor vehicle it will be simply plug and play. If you just pull the wheel, you will need the correct clock spring as well. If you just plan on swapping the wheel, pull your old wheel and photograph all the connectors. Find the donor wheel and check the connectors against your photos. They should be the same, but you wont know for sure till you eyeball it.
1 - 3 of 3 Posts
