Power Distribution
AM Radio
Premium Sound AM/FM Compact Disc Radio
Pin Number Circuit Circuit Function
1 803 (BR/PK) Amplifier/Speaker Switch Ground to Right Rear Speaker
2 806 (PK/LB) Speaker Voice Coil Feed — Rear (Right Channel)
3 811 (DG/O) Speaker Switch Ground to Right Front Speaker
4 805 (W/LG) Speaker Voice Coil Feed — Front (Right Channel)
5 801 (T/Y) Amplifier/Speaker Switch Ground to Left Rear Speaker
6 807 (PK/LG) Speaker Voice Coil Feed — Rear (Left Channel)
7 813 (LB/W) Speaker Switch Ground to Left Front Speaker
8 804 (O/LG) Speaker Voice Coil Feed — Front (Left Channel)
Radio Connector C2, AM, AM/FM, AM/FM Cassette
1 694 (BK/LG) Audio Ground
2 — Not Used
3 694 (BK/LG) Audio Ground
4 — Not Used
5 19 (LB/R) Instrument Panel Lamp Feed
6 137 (Y/BK) Ignition (Hot in ACCY or RUN)
7 57 (BK) Ground
8 797 (LG/P) Battery Feed to Stereo
Harness Connector to Jumper, Premium Sound AM/FM Compact Disc Radio
2 — Not Used
4 — Not Used
7 57 (BK) Ground
Radio Jumper Harness Connector, Premium Sound AM/FM Compact Disc Radio
1 689 (DB) Logic Mute
2 — Not Used
4 — Not Used
7 57 (BK) Ground
Radio Jumper Radio Connector C1, Premium Sound AM/FM Compact Disc Radio
1 855 (LB) RR AMP Input Return
2 278 (P/W) Rear Speaker (RH)
3 858 (BR) RF Input Return
4 279 (W/R) Right Front Speaker
5 859 (Y) LR AMP Input Return
6 277 (LB/BK) Rear Speaker (LH)
7 857 (W/O) LF AMP Input Return
8 280 (LG) Left Front Speaker
1 803 (BR/PK) Right Rear Speaker Return (-)
2 806 (PK/LB) Right Rear Speaker Feed (+)
3 811 (DG/O) Right Front Speaker Return (-)
4 805 (W/LG) Right Front Speaker Feed (+)
5 801 (T/Y) Left Rear Speaker Return (-)
6 807 (PK/LG) Left Rear Speaker Feed (+)
7 813 (LB/W) Left Front Speaker Return (-)
8 804 (O/LG) Left Front Speaker Feed (+)
9 — Not Used
10 — Not Used
11 — Not Used
12 689 (DB) Logic Mute
13 694 (BK/LG) Audio Ground
14 797 (LG/P) Battery Feed to Amplifier
Premium Sound Amplifier Connector C1
1 857 (W/O) LF AMP Input Return
2 859 (Y) LR AMP Input Return
3 858 (BR) RF AMP Input Return
4 855 (LB) RR AMP Input Return
5 280 (LG) Left Front Speaker
7 279 (W/R) Right Front Speaker
8 278 (P/W) Rear Speaker (RH)
Premium Sound Amplifier Connector C2
2 — Not Used
4 484 (O/BK) Liquid Crystal Display
7 57 (BK) Ground
Radio Connector C1, All Non-Premium Sound Radios
