That's a valid question..there are only so many places it could be leaking from up there. are you able to get an eye on where the head sits on the block, or is that completely blocked by the smog pump?? I'd also suggest double checking all your hose clamps up top and the condition of your radiator hose as well as the heater hose where it goes into the intake..there's a fitting up there that has a tendency to rust..yours might have a hole in it..I’m quite a novice. If I can’t see it, how would a pressure test help?
