I've removed several stock radios with no problem. I'm having difficulty removing the stock radio from my 95 Eddie Bauer. Any suggestions? Tricks?
Steve83 said:Are you using the U-tools? Just push them in until they snap & lock, pull them slightly OUTboard, & pull the radio out. QUOTE]
This procedure has worked in the past but not this time.
95_G&W_XLT said:I never had a problem with U-tools.QUOTE]
Me neither.....till now.
Outstanding idea. It worked and the radio is out. Thanks a bunch.bronco1 said:Some times the retainer outward stops deform or break allowing the retainer to move too far outward,you may have to grind the removal tools to a taper to get in behind the retainer(the taper should be with the sharp edge away from the radio .If that doesn't work,then you will have to some how get in behind the radio to push the retainer towards the radio with a screwdriver or ?. Hope this helps and good luck,bronco1.
