1 - 8 of 8 Posts
With my stock brakes, I couldn't stop my '78 in 1st gear 4-low with the clutch out (SM465, NP205, 4.56 gears & 36" tires). Today I finished up the F-350 brake upgrade (MC/booster, wheel cylinders, T-bird calipers + braided stainless steel lines everywhere), and it still won't stop in 1st gear 4-low. It seems like it's getting closer to stopping, but that may just be wishful thinking. Pedal feel is comparable to stock, maybe a little firmer.
I've just been crawling back and forth in my back yard and haven't yet road tested to see if I can lock the wheels at speed; previously I couldn't.
For other with similar vehicles/brakes, are you able to stop in 4-low 1st with the clutch out, or is our low just too low for anything short of a major brake overhaul?
BrokeCuzWheelin said:
If you push in the clutch the brakes will stop it just fine.
:thumbup
I'm using 1st 4-low as a yardstick for stopping power because if something fails during testing, I'd rather bonk into whatever's ahead of me at 3 mph than 30.
FSB warrior
soksniffer said:
That adapter must have been expensive, you sure its not an NP-435 or T-18.
Excessively Engineered
Just push in the clutch and stomp the brake? Don't run it in 4 low. Umm start out in second?
Disk brakes all around. The lower you go the harder it will be to stop in low 1st. Just think what it would be like with a doubler.
I think the perfect setup with a manual is to be able to stall in gear so you can restart and crawl right away. No clutch on the restart. You are just about at the perfect setup.
my bronco has not had the best brakes on it since I put the 1 ton front axle in. but the stock brakes could always stall my fresh 400 with 4.56's, np435 and 205 in low.
1 - 8 of 8 Posts
