Hey guys, need some help. 1988 302 AOD Bronco. With spark tester on coil secondary, get one spark when starting to crank over, one when releasing remote starter button (KOEO). With test light at coil negative and ground get bright light with KOEO, dim light , no pulsing when cranking. Have 12V at BOTH sides of coil with key on. Have 12+ volts at #4 terminal of ICM. Put black dvom lead to module connector #6, Red lead to battery positive, have 12+ volts. Applied battery voltage to #5 of ICM with test light, no pulsing of light when cranking (key on) Module tests were performed by back probing wiring. Coil secondary 7.85K Ohms, primary .9 As an afterthought, problem started a few months back in hot weather, truck would die, then restart after a few hours. Only used truck to commute, so plenty of cool down time between run times. The last few times it wouldn't start, I hooked up spark tester to plug wire or coil , and then it would start! (this only worked a couple of times before getting home on a hook) Not many things look sadder than a Bronco on a tow truck. Any suggestions will be VERY appreciated
