You sure you want your transmission, t-case, etc rebuilt when they could be perfectly fine?
The stock intake is the best cold air intake.
Your floor board bump sounds to be like Radius arm bushings. Search for them on our search feature, there might even be a write up. You will know when they are bad because the the rubber bushings will be cracked or even have some chunks missing out of it.
