stripped lockout bolt ***FIXED***
I was changing my lockouts today & on the passenger side i stripped a allen- bolt. there were two others also but not as bad,i used a torx bit & got them out, but this one is really rounded out. any suggestions?
We got 8-10 inchs of snow last night & when my old lady went to go get some groceries she got stuck in the driveway, i taught her how to lock the hubs, then put into 4 hi, but failed to tell her to let it engage before shit canning it. well, i heard a horrendous grinding then a loud clunk. :cry when she got back i thought i should check it.turns out the free spining gear that meshes with the other to engage it was just hanging there with a bunch of shavings inside the hub.
drill the head off and slide the hub out and then you can just turn it with some pliers
Drill it out,its actually very easy because the hole centers the bit. You only need a 1/8" (maybe slightly bigger) bit too because you only need to drill the head off, not completly out. Once the head comes off pull the lockout out
FSB warrior
GOod one:thumbup
You can also use an easy out that is about as big as the head, but thats a PITA
I'm going to go & try to drill it out. probably the only way to get it off. I tried everything i had to get in there and back it out but nothing worked.
This is the best course of action at this point.
drilled the head out,pulled the hub off,backed screw out with a pliers. I already have the new lockout on. easy as that :thumbup why i didn't think of that? i don't know.:banghead Thanks guys.
