i have a 94 5.8L Bronco
it has 202,000 miles
the motor is in excellent shape or seems to be anyway.
i just did the Ignition Upgrade that i read about on here.
the Problem was there before this and is still the same.
if i give it the gas real fast it will Stumble.
if i ease into like everyday driving it will do fine except for a little Hesitation.
Yesterday i was playing with it and just nailed it real fast and it would Stumble then Pop real loud.
any help i would be thankful
Travis.
Check the spark plugs and wires. Make sure the boots are secure on the plugs and visually inspect the plugs for fouling.
they are new as of yesterday.
motor is not running rich.
new 9mm Wires as well.
it was like this before the new stuff.
thanks Travis
thanks Travis
Mine used to do the same thing. I installed a MSD 6A, MSD coil, MSD cap, and new plugs. Now you step on it and it just goes, yahoo!
:rockon
it acts like its not taking the throttle for some reason.
FI vehicles shouldn't do this.
i have all MSD components installed along with new Plugs and 9mm Ford racing wires.
Throttle Position Sensor? (TPS) -
Probably intake gasket leak or severe vacuum leak.
Could also be leaking egr, gummed up injectors, or any number of EEC issues. Pull trouble codes and post up results.
