1 - 14 of 14 Posts
I was going to check the timing on my 80 F250 (5.0L - Carburated) and while looking at the balancer, there are no marks on it except for one big notch.
The pointer is also different, it just has a hole in it. Not your typical pointer that lets you see where the timing actually is. And, it's tucked way underneath the alternator. I don't know how you could even see it if it was adjustable.
I know there are certain distributors that are controlled by a computer, but after ripping my truck completely apart for a rebuild I did not see anything other than the Duraspark box on the passenger side inner fenderwell. The dizzy does have a vacuum hose hooked up to the carb for advance, so I just assumed that it could be adjusted.
What gives? I'd like to know where my timing is, but don't have a clue how to check it.
:whiteflag
My timing marks are on the harmonic balancer. I used chalk to fill in the grooves and numbers. If you have no marks or numbers I would think something is not right. If you've never timed a vehicle before I suggest you gfet instruction prior to trying it yourself.
Practicing Infidel
:whiteflag
Theyz there but they could be under rust or paint. I sanded mine down, shot a light coat of black spray paint and then marked them with a white paint pen.
Others just rub white chalk into the fine grooves and eva-thang gets right visible-like for yuh:toothless
Sixlitre
Guys, it's not like I've never set engine timing before. I know all about disconnecting the vacuum line, wiping chalk on the balancer, blah, blah, blah.
I have rebuilt many engines, worked for quite a few racing shops with dyno's, been to too many race tracks to count.
What bugs me is the lack of a typical timing pointer on the cover. It's just an "O" shaped piece of tubing welded to a flat piece of sheet metal. There is no pointer to speak of, and I am almost positive there are no marks on the balancer.
Almost as if there should be something like a crank trigger that would see the one and only notch in the balancer.
Nobody has ever seen this before on 80-86 302's?
Kitteh Commandaar!
Buy a new harmonic balancer, with timing marks on it....? Seems to me this is about the only way, unless you can set time by the sound of the motor...
KC
This was pretty common on the old carb trucks. Use your timing gun you just look through the hole or pipe and that's the reading. Basically the timing line mark on the balancer should be centered in the pipe looking down. Not fords best idea ever, but I have seen stupider things lol
Discussion Starter · #9 ·
Yeah, ok. But what is it showing you assuming that you can get a damn timing light down under the alternator to see it in the first place?
TDC, 6 degrees BTDC, etc?
I have no way of accurately knowing where the timing is.
Sixlitre
We use an "S" instead of a Z in America. Mexicans use Z's here. How come y'all don't speak French up there anyway???
Practicing Infidel
Fear not Dave
our 17% French minority is working on us all learning French:doh0715: The [email protected]%&suckers already constitute 58% of the civil service and they're going for more.
I just use the "z"s when I'ze talkin' hick/*******:toothless.
Sixlitre
1 - 14 of 14 Posts
