I saw a thread sorta similiar to this, which was about something you did to your Bronco today. So today, after pulling one of the stupidist things I have done in a while...I figured that I needed to let everyone know about it and see if I am the only one that does stupid things...or if there are others out there like me. So here ya go......
I was about to do the first oil change on my new '79. Now...I am not a mechanic by any means, and maybe have changed oil in my vehicle 6 times in my life. But, this is not to say I am not mechanically inclined, just always worked for companies that paid for my oil changes.
So, while I am under the Bronco, I start to remove the oil plug. To prevent the oil draining out at an angle, and missing the fancy oil changing container sitting on the ground, I go and get a milk jug, with a funnel, that would raise it up higher. The funnel was real close to the drain plug, and I was confident that I was on my way to a dripless...spotless oil change.
So when I unscrewed the plug, it dropped into the funnel as planned and the oil drained into the funnel/milk jug PERFECTLY...just as I had planned, not a drop of spilled oil anywhere..... for about 4 seconds.
All of a sudden, the funnel started overflowing and oil was going everywhere...all over the ground. PANIC SET IN...as I could hear my wife freaking at the mess on the back driveway, when she saw it.
Still panicing, I figured that the pressure building up inside the milk jug must prevent the oil from draining into it properly, so I lifted the funnel higher to allow the air in the milk jug to escape. Surely the oil would flow into the jug as planned. No luck...oil still flowing out a a very high rate. Puddle of oil about 2 feed wide by now. Imagined sound of wife screaming getting louder in my head.
Short story is that the drain plug had dropped perfectly into the opening of the funnel, thus creating a plug in the opening and allowing only a small amout of oil to flow into the milk jug.
HOWEVER, the second issue I would have faced was the fact that a milk jug is only 4 quarts....and a Bronco holds 5 quarts. Either way, I was headed to a cleanup!
So, my 10 min. oil change, turned into about a 45 min. ordeal, after soaking up all the oil with shop towels and scrubbing it up with other stuff. Never before has so much toxic waste been created from a simple oil change.
Live and learn.....
Live and learn.....
