What are you guys doing to repair this when it falls out?
Joisey don't smell funny
78 Bronco Custom, 460/ZF5, Sniper upgrade, 3G, dual batt
Following this as I have the same issue.
So I found this thing.
How do you get the old broken one out? I'm pretty sure the entire thing did not come out.
Anyone drill it and use maybe a small easy out to get a hold of it?
The opening that the pin mounts into has got a bit of a taper to it. I used a long drill bit that was a few sizes smaller than the pin diameter. I was very careful to keep it centered as I drilled out the old plastic pin. Then I used some dental picks to pry and scrape out the remnants that the drill left behind.
Got the old one's out. Can see the broken piece here.
Drilled hole in it
Used easy-out
Pulled right out, super easy.
This place had best price, mostly cause they use USPS, so shipping only $6.
Reactions: 2ndHelping
