I want to replace mount bolts on lift/pivot bracket and want to know how I should support it (if even necessary) while I remove/replace a bolt.
I'm thinking just lift Bronco via front frame/taking some pressure off front suspension.
Would that be enough?
Would that even matter?
For clarity;
The lift bracket is for the passenger side TTB.
The pic is of said bracket/front view.
Bolt in question is the upper right bolt/that bolt goes through both sides of bracket/said bolt is about 5" long.
Said bolt holds/supports both sides of bracket.
HOW SHOULD I APPROACH THIS?
For clarity;
