Got a 79 bronco, both rear sway bar brackets rusted threw and broke off on me. I Trying to find the bracket, only ones found was ones autozone and them have. Only problem is the bolt holes on the bracket don't match up. Was wondering if it be ok to drill them out a little bit to make them work? Also I was told to measure the bar take an adjustable wrench and place it on the bar then take off and measure inside diameter of that. This will give you the size of the bar. Only thing is I did this on a straight part of the bar but looks that part is bigger then where he bushings go. Is this the correct way or should i measure where the bushings go? If not then the reading im getting is the sway bar is 1 1/4.
