1 - 4 of 4 Posts
ok,..im sure this has been covered and search just keeps coming up with tailgate motor problems.....
my motor is fine...but the only thing holding my tailgate up is the spare tire holder and the glass pressed inside the top...
the latches inside each side of the tailgate dosnt lock....is this a common problem?...is there an easy fix for this?....
its really not a big deal right now...its not street leagal,..but eventualy id like it fixed....
Banned
If neither side latches, it's probably an alignment problem with the TG. A body shop should be able to fix that.
www.easttn4x4.com
This is a common problem. You need to take the latches out and lube them with spay silicon. Work them manually in your hand many times and keep them good'n wet. Once they free up put them back in and your problems will be fixed.
1 - 4 of 4 Posts
