1 - 2 of 2 Posts
my rear window wont go down, i checked the fuses and theyre all good. i purcashed a new window motor hoping this is going to be an easy fix. any tips or hint to make it easy??,, thanks
F.O.T.M. - MAY 2014!!!
After taking off the access panel, there will be 3 bolts holding the motor in. If the glass is stuck up, you can lay in the cargo area and do this job. The glass will should not slide down when you pull the motor off.
1 - 2 of 2 Posts
