The window in the back doesn't work on the switch but will work when hooked to a battery. What could be the problem. worked at one time, but quit
thanks
justin:whiteflag
Do a search in the genreal section, youll most likely find your answer... and your question is pretty broad too...
cables crossed... wires broke... fuse blown... switch gone... ground wire bad... a lot of answers... chase the wires... does the motor work when connected to a battery right behind the switch or right in front of the motor?
josh money let me tell you that that is not the best way everybody thinks the motor is circuited and go and buy a new one but is not nessesary puto! you only need to search the wires that are broken or just cut!!
