1 - 4 of 4 Posts
Ok its like 5 degrees and snowin and my window is the only thing holding my tailgate up. Is there an adjustment or somthing for the latches or WTF do i do? :banghead thanks guys.
Charlie don't surf..
'92 Ford Bronco XLT
What do you mean your window is the only thing holding your tailgate up?? you can't close the tailgate with the window up. put the window down, close the tailgate then raise the window. Sometimes I have to slam mine to get it to close right.
Think i fixed it for now.
I took the panel off of the inside of the tailgate and put PB Blaster on every moving part that i could find and worked everything back and forth. Then i took the strikers off and flipped the little plastic things on them around so the latches have a new spot to catch. :rockon
1 - 4 of 4 Posts
