1 - 9 of 9 Posts
didnt see anything when i searched, but im assuming the only tailgates that will fit the 78-79 bronco are tailgates from 78-79broncos. or am i wrong? will any other tailgates from other years fit?
there isnt one. hahaha, when my friend first aquired the bronco there was no tailgate on it, something happend to it when the original owner was stationed at some airforce base, ive heard the rear rotor on a helicopter ripped it apart, but sounds like BS to me, so idk, i just need one before im driving this thing on teh street
yes
http://www.medicine.wisc.edu/~mrm/bronco/tailgate.html
Tailgate Swapping
Amazingly throughout the number of body style changes from '78 through '96, the tailgate remained nearly the same. You can swap tailgates between all of these years taking note of the following:
I've broken down the 3 major changes into their respective years.
78 - 79 Type A
80 - 82 Type B
83 - 96 Type C
If your swapping within the same "type" it's just a direct swap.
If swapping A & B you have to switch the glass and glass support brackets
If swapping B & C you have to switch latches and striker plates
If swapping A & C you have to switch the glass, glass support brackets, latches & striker plates.
1 - 9 of 9 Posts
