1 - 20 of 23 Posts
i heard if you take the shell of the back that the seal isnt good anymore and when it rains it links alot is that true>
when the carpet gets wet and doesnt dry it reeks like hell, grows mold too.
Too poor for FSM
No just be careful with them. There not a one time deal, but if the seals break, than yes you will run into problems.
-Vance
Thanks 351w500
Ive had 5 bronco's still have 3 of them. The tops are on and off on all of them every yr and i have NEVER had a leak or a problem.
order one of what? everything on the page?
:doh0715:
that shits way too expensive, couldnt you just get some generic weatherstriping for the top for like less than 20 and be done with it?
B350 built at THE SHOP
buy replacement bolts with regular hex heads, they are way easier to work with when you put it back on.
Side step it
I used to put some vasaline on the w/strps when I took the top off but now just spray a "Dry silicone" spray on them. 3m makes a w/strp conditioner plus, you can still buy new ones pretty cheaply....-Kevin-:thumbup
The tops come off the broncos?!
:goodfinge
:histerica
I tried with the hex heads and wasnt able to find the correct pitch and size so I jest ended up screwing up a couple of the brackets. I went back to the torx head ones and theyre great. The best thing to have is a spare torx or two and an air compressor.
Also to seal mine back up i just used the chit out of some clear or black rtv. Vaseline is something I have heard of working too. Pretty easy cleanup, and effective throught the rain
:goodfinge
:histerica
Yes the tops come off, you non bronco havin muther f#$%^&.
1 - 20 of 23 Posts
