1 - 3 of 3 Posts
Building gold from crap
are the controls for the heat, and air, and the fan control electric , vacum, mechanincal or what for all year broncos, thinking of what would be involved in a dash swap, to make the controls work. like 92-96 dash into a 80-86 bronco
My 81 is all cable controlled,and it doesn't have air conditioning.92 -96 are vac. controlled,except i believe the temp control is cable.My 81 has a 93 dash,but has the 81 heater box and controls.The 81 was only floor and defrost,so no vents,which i had to cut out of the 93 dash to clear the 81 heater box.I had to make a new bracket to bolt the 81 controller to the dash too,they're shaped a little different.I don't know what would be involved in mounting the dash,because mine has a 95 cab,so it was a direct bolt in.I mounted the 81 instrument cluster in that dash too.
shibby
Directional control (dash, vent, floor) is vacuum actuated, cold/warm temp is cable actuated, blower speed is electrical..
1 - 3 of 3 Posts
