Ok , temp guage keeps going into the red , top hose fairly cool , no leaks , runs and starts good (no dieseling noise like its hot) holds pressure , clutch fan ?? Guage ?? 91 5.8 , just scary driving it like that , can't use search on my phone sorry
If the top radiator hose is cool after you ran the engine then your T-sat is not functioning or it's in backwards so pull it out and test it in hot water to see if it opens and if not replace it with the correct temp degree, mine is 195* AND while you're at it "backflush" the cooling system with plain water until it flushes out clean, wash any re-useable hoses in detergent, clean out the over flow tank, replace the old radiator cap with a new one then top off with good quality anti-freeze and you'll be good to go for a while.
If you have the time and energy...lol lol...pull off the "box" under the dash around the heater core and look inside to see if you have any leaks or corrosion and clean it out, replace the HC if necessary.
With backflushing, clean or new HC you'll have really nice heat for the winter....:doh0715:
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
