Hello everyone, this is my first post here and im sad it has to be about a problem. After about 55 60mph, the car shakes pretty bad and it hard to control, it sways alot and there is alot of play in the steering wheel. I bought an 87 bronco tonight with 33 x 15 x 14.5in MT hp's, with a 3in body lift and a 2in skyjacker lift with add a leaf in the back. it also has new rancho shocks all the way around and two rancho steering stabilizers... i have all the reciepts for this and even a receipt for an alignment and balance....
What could i look into first? Im pretty stumped, i have yet to inspect throughly but id like to know what i should check in the daylight tomorrow.
thanks!
Charlie don't surf..
'92 Ford Bronco XLT
Tie rod ends, ball joints..even if it was aligned and these were bad you're going to have problems.
aka: kemicalburns
also having a 14.5 wide tire doesnt help one bit. do like oscar said and try a different set of tires. have someone turn the steering wheel while you inspect the front end, if the steering moves more then the tires then your ti rods are shot .
