1 - 15 of 15 Posts
FSB's Resident A$$HOLE
just saw this on pirate, dan dibble finally finished his 4 seat buggy. it is built for wet rocky trails out east becuase he is located in tenessee. here are the specs:
454 rat motor, th400, atlas 3, 2.5 ton rockwells, 44 inch cut boggers, 15 inch beadlocks, coilovers and 4 links.
BY FAR THE BADDEST 4 SEAT BUGGY ON THE BLOCK!!!!
wes
Ogeechee 4x4 said:
i'd just like to have the money he sunk into that thing :shrug
i would just like to know the cost of it period! rockwells arent too bad, about the same as a built 60, but the rest of it is a ton of money
and ya, he still hasnt cut the last bogger, his excuse was that he was finishing the rest of it!
wes
hates EVERYTHING!
Better traction, and no not siping...look at the driverside front...see the big lug little lug pattern?? Now look at the pass. front and drivers rear, he's cut out the little lugs leaving the big lugs and now they are spaced out more...Better self cleaning lugs in mud, and more bite on rocks...:thumbup (actualy if you look close the drivers side is partialy done)
Discussion Starter · #12 ·
the use a tire groover and a lot of time most of the time. ive even seen people use a sawzall, and other crazy tools to do it, but a tire groover is most often used
wes
1 - 15 of 15 Posts
