Not Frilly.
I recently put a steering stabilizer on the bronco, I figured the bar would stiffen the front suspension, thereby removing my right wheel wobble, it did but i'd like to know if anyone knows why it worked like that?
you took the ability of your steering to resonate away, you dampened the vibrations so they cant build, unfortunatly, you didnt fix what was causing it to start, just hid it, and it will come back, ask me how i know.
Like Gilla said you have basically put a band-aid on the problem. It will come back.
Have you checked your TRE, ball joints, and check all the bushings up front.
Not Frilly.
Needs new TREs needs an alignment, my dad just wants to rotate the tires because apparently alignments are miraculously 300 bucks. that is most likley what caused the original problem.
