yo,
was thinking of the "wet arm" (no jokes please) wiper arm/ blade combo for all year or winter only use;
Many are made for heavy truck, & marine apps, but can be fabbed up by runnung hose thru a new opening in cowl and along arm to blade and use a 92-96 MY Nozzle or a diy nozzle (more on this when I get home) as 95F1504x4EB showed above.
Also, we used to run - w/new coolant bag, the line along heat hoses (taped to hoses that go to heater core) so as to help keep washer fluid from freezing when driving on highway at speed.
Here is an AFi catalog that should show the arms
http://www.comstedt.se/kataloger/pdf/AFI 08 catalog.pdf
see page 15
AFI Premier wiper wet arms combine the heavy-duty construction
and materials of the Premier wiper arm line with a built-in wet arm
system that allows for a clean and easy installation of a washer
system. A simple and easy way to keep your windshield clean, the
Premier wet arms feature a black PVC hose that runs up the center
of the arm and ends in a four-nozzle fixture that is an integral part
of the wiper arm itself. Each solid brass nozzle is adjustable to
provide a maximum coverage spray pattern for most any windshield.
Premier wet arms can tie into an existing pressurized water
system, or can be used with the new Below Deck Washer Kit as
shown on page 19.
Premier Single Wet Arms Adjusts 15” to 20”
these are $$; about $90.00 each at boat supply stores
