I have a thermactor tube installed on my 315m just behind the the dizzy. It has a valve of some sort where the rubber hose connects to it. My problem is that the valve is so corroded and rusted that the valve practicaly works like a cap for the tube. Has any one every changed these tube assemblys out. I also noticed a 351m in the junk yard with this hole in the manifold pluged. Could I just remove the tube install a plag and get rid of the smog sys. I found a good replacement tube in the junk yard but it was a bitch to get off. I didnt have a braker bar or any wd40. So I had to leave it. James :banghead
